1. uninstall S3D with remove licence
2. regedit, delete s3d keys
3. install S3D
4. start S3D, login (click remember) -> it starts ok
5. close S3D
6. start S3D -> it starts ok
7. you can do 5-6 many times, it's ok
8. import attached FFF
9. do whatever, close s3d
10. try to start S3D -> won't start (Not Responding)
11. goto 1
I don't see anything weird in the FFF but ... I tried this 10+ times, happens every time
Embed M117 codes into G-Code
open source and unlicence
weird, looks like it has nothjing to do with this fff ?!?!?
uninstall, clean registry manually, clean registry with ccleaner, clean progdata, appdata ... install new, it works till I add new material, the moment I add new material and exit s3d next time I start it it just shows white empty window with header s3d licenced to .. not responding ..
sent email to support, hopefully they will ping me back soon...
this is weird, this started happening on a brand new machine (ryzen 9 3900x 12 core, 64G ram, windows 10) where not much apps exist (still have not had time to setup nothing, apart from nececities like putty, firefox and notepad++ there's visual studio code and visual studio 2019 and that's about it) ... kasperski 100% disabled / enabled made no difference, added to safe apps in kasperski, no difference.. so not sure AV is to blame.. weird ..
while not very active on forum, s3d replied super fast on the support request and we solved the problem... the problem was with nvidia driver, after I reinstalled the nvidia driver I had to once more reinstall s3d and now it works fine
