Page 1 of 2
S3D 4.1 crashes on launch
Posted: Tue Sep 17, 2019 11:40 am
by mrKayne
Hi!
I've also asked the support directly for help, but until they respond, I might aswell try my luck here.
I'm running Win10 Pro 64bit, freshly updated.
When I run the program, it just freezes up right away with a white screen. It gives me no errors or anything.
I tried to reboot, reinstall and also tried to clear the AppData S3D folder as suggested in an other thread, but no luck.
So... any of you guys have an idea?
Thanks!
Re: S3D 4.1 crashes on launch
Posted: Sun Oct 13, 2019 1:29 am
by PaulK
I'm also got the same problem.
Win 10 Pro, 64 bit, S3D 4.1.2, opens to a white screen and then stops responding.
Posted: Mon Oct 14, 2019 1:24 pm
by nogarth
Yup same issue here windows 10 Pro latest verions on all.
to fix have to delete
REG KEY
HKEY_CURRENT_USER\Software\Simplify3D
Posted: Tue Oct 15, 2019 11:01 pm
by PaulK
Thank you - that fixed the problem.
Posted: Wed Oct 16, 2019 9:00 am
by arhi
if you delete WHOLE registry that will kill your settings and everything else :( .. not a very good solution
try to delete only GEOMETRY keys
so
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\Communicator\geometry
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\FFFWindow\geometry
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\MainWindow\geometry
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\SectionDialog\geometry
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\SplitProcessDialog\geometry
HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\SupportGeneration\geometry
and see if it will fix the problem
these keys only keep "Where did you left your window open last time"
the problem is, windows 10, if you move your s3d window to the non-primary screen (assuming you have multiple monitors) and close it, next time it will try to open on that non-primary screen and it will freeze. it is a wxwidget bug: https://trac.wxwidgets.org/ticket/18532
please try if that works for you... to freeze s3d again move it to non primary screen and exit s3d, next time you start it will try to load on that same screen and it will freeze ... delete the geometry keys and it will work again.
this bug is also reported here: viewtopic.php?p=52776
Posted: Thu Mar 05, 2020 5:52 pm
by nogarth
this happened again to me after GFX card update drivesr. so i followed OP and it worked just the geo reg entrys. thanks
Posted: Thu Mar 05, 2020 11:33 pm
by arhi
nogarth wrote: ↑Thu Mar 05, 2020 5:52 pm this happened again to me after GFX card update drivesr. so i followed OP and it worked just the geo reg entrys. thanks
can you share your hardware ? you have nvidia and windows10?
this looks like nvidia issue on windows 10, I have this identical bug with slic3r, netfabb and bunch of other software
Posted: Wed Mar 11, 2020 10:45 pm
by snlink6
having the exact same issue, and sadly the S3d support site ticket system seems to be down, i'm unable to even send in a ticket for support
S3d 4.1 crashing on launch
-I get a white screen crash every time I attempt to open S3d.
I have uninstalled and reinstalled the latest version, but no change.
The only thing I've tried that has worked was a regedit deletion of the regestery keys for S3d from current_user, but that only works until I start S3d again.
Windows 10 x64 bit - updated
s3d 4.1 updated
Nvidia geforce 2080 drivers - updated
Posted: Fri Mar 13, 2020 7:35 am
by arhi
more than one monitor? cpu? amd or intel? this I started having after I moved from win7 intel to win10 amd ryzen .. same nvidia card... it's a bug in nvidia driver, not in s3d, you do not have to delete whole registry, just all the "geometry" keys
on dual monitor issue is if you leave your s3d window on non primary monitor it stores the location to open it there next time (in those registry keys), when you try to open the app on non primary monitor nvidia shit it's pants: https://www.nvidia.com/en-us/geforce/fo ... apbuffers/
Posted: Thu Mar 26, 2020 11:31 am
by oftebro
I tried the RegEdit and deleting all the Geometry items and it didn't work for me.
I got this info from Simplify Support. Worked great!!
"Thank you for your e-mail. I am happy to help.
Could you please try navigating to your Simplify3D working directory (likely at C:/Users/%USERNAME%/AppData/Local/Simplify3D/S3D-Software) and deleting the savedState.factory file? This is what loads the previous state when launching the program, so if something too large was saved, or if the file got corrupted, this could cause the failure to launch that you are seeing"
Thanks to the community and Simplify Support!!
