Help diagnosing print quality problems
Posted: Fri Sep 27, 2019 4:26 pm
I could use a little guidance on how to fine tune S3D to produce better results. Factory file attached.
Basics
This is what I think is going on
Basics
- PETG
- 0.8 mm nozzle, hardened steel
- 230 C nozzle, E3D volcano, BMG extruder
- 60 C bed
- 100 mm/s nominal speed
- Ball-screw/stepper driven machine, custom built
- A - Might be a cooling problem?
- B - I think this is caused by the infill rather than any mechanical issue
- C - Z seam showing through
- D - Not sure...z seam issue?
- E and F - At first I thought this was due to some kind of a backlash issue with the Y axis screw/nut. That doesn't match what I am seeing on other prints and the lower portion of this print. Now I think it might be related to the infill and how it changes shape at those locations.
