Solid Infill Between Perimeter and Infill
Posted: Tue Oct 01, 2019 12:27 pm
by andyjhas
Simplify3D is putting a thin solid infill section between some perimeters and the infill and I can't figure out why or how to get it to stop. It causes the printer to have short jerky movements and I think its the cause of my prints failing. The only way I have been able to prevent the jerky motion is using concentric fill. I have a CR-10 s5 with an E3d all metal hotend and printing with PLA and the extruder grinds up the filament during these types of movements when it is only extruding a small amount of plastic.
The problem
-The layer after the solid bottom infill
-A layer higher up on the part
With concentric fill
-andyjhas
Re: Solid Infill Between Perimeter and Infill
Posted: Wed Oct 02, 2019 11:12 am
by airscapes
Advanced tab, change from gapfill to allow single extruded fill and see if that removes the gap fill Zigzags
Posted: Sat Oct 05, 2019 1:12 pm
by andyjhas
Didn't work, the zigzags are still there.
Posted: Mon Oct 07, 2019 9:20 am
by horst.w
Hey, sorry, can't find your FACTORY-File you have attached
GER
Posted: Mon Oct 07, 2019 10:30 am
by NickelPLate
I'm having the same issue. I'll have to try the single extruded fill when I get home. These zigzags shake my printer pretty violently.
Posted: Mon Oct 07, 2019 2:58 pm
by horst.w
The coloring of this "zickzack" indicate it as "infill".
Infill is only printed in closed enviroments such as walls or cubes ; nevertheless bottom and top layer may be set to "0" so you can see the infill.
H.
