Missing Object
Posted: Sat Aug 30, 2014 6:44 pm
by dan
sometimes when i import a model and prepare it for print and then go back to import another model
and then again prepare for print, the second model is not being calculated to gcode.
I have to close the prgram and then do it again to see the results in "Prepare to print"
Re: Missing Object
Posted: Sun Aug 31, 2014 11:38 am
by TenKOhms
When you slice a model s3d associates models with their respective processes'. When you exit the preview mode and import another model it doesn't automatically get associated with processes', so you will have to open the FFF settings window, find the button that says "Select Models", and select the model you just imported.
Re: Missing Object
Posted: Sun Aug 31, 2014 8:49 pm
by tri-lite
Since I frequently run into that same problem, I added an image so you can see where to find the buttons.
Double-click on your Process to open the FFF Settings window.
1. Click on the "Other" tab.
2. Click "Select Models" at the bottom.
3. Click "Select All" to make sure your process applies to all models.
Re: Missing Object
Posted: Mon Sep 01, 2014 12:38 am
by dan
thanks guys :)
