Top/Bottom Solid Layers in printing a range of a part
Posted: Sun Oct 06, 2019 10:35 pm
The way of S3D deaing with "Top/Bottom Solid Layers" seems to be confusing.
For example, a solid cylinder is of the height 100mm. Both Top/Bottom Solid Layers are set to 1, and Primary Layer Height is set to 1mm
● Process A printing height 0~100mm gives a cylinder with a top solid layer and a bottom solid layer.
● Process B printing height 30~70mm ALSO gives a cylinder with a top solid layer and a bottom solid layer.
In my understanding, Process B should give a cylinder without top/bottom solid layers. In fact I observed this did happen in some sophisticated models.
Could you kindly share your opinion about this? Thank you!
