Extrusion Problems/Gaps in top of print
Posted: Thu Oct 24, 2019 10:03 pm
by aneta8duetwifi
Hello, I have a problem that really has me scratching my head. I just recently purchased simplified 3d. I love it but im having trouble figuring out what is going on with my printer. the first layer prints beautifully.after that it kind of seems like it is over extruding but not worried about that per say. not yet anyways. it prints okay until it gets to the top layers. it tends to leave gaps in the print. I have tried to adjust my print settings little by little and one by one. im not seeing a whole lot of change. here is what i have done so far and this is the fifth round of testing:
5.1- I removed coasting.
Results- inconclusive
5.2- I removed retraction.
Results- better in a sense. Now there is stringing, but that was expected. The gap is almost gone on the top of the model.
5.3- adjusted extrusion width from .48mm to .45mm
Results- gap almost completely filled in, but worse z seam..
5.4- adjusted extrusion width from .45mm to .40mm
Results- can’t quite tell any difference from 5.3
5.5- adjusted extrusion width from .40 to .35mm
Results- gap is back but better z seam.
5.6—adjusted allowed perimeter overlap from 12% to 20%
Results-gaps fractionally worse
attached are some pictures of my 5.1 print just to give you some idea of what i am talking about.
i am using, well for this experiment, hatchbox pla at 205°C print speed hasn't really effected anything either. my layer height is .2mm and my nozzle is .4mm brass. i have changed out my nozzle 4 times and no changes.
Re: Extrusion Problems/Gaps in top of print
Posted: Fri Oct 25, 2019 7:46 pm
by aneta8duetwifi
i am still having problems with extrusion. i did figure out that when i set up my slicer to the out of the box anet a8 profile that is provided it does work better. when i change the number of extruders to 2 it just doesn't want to fill small gaps and the top layers. please does anyone have any suggestions or ideas let me know.
Posted: Sat Oct 26, 2019 11:31 pm
by S3D-Jake
Attach your factory file? Some common tips here would be to make sure the layers are getting slowed down at the top as the part gets smaller and smaller. Also, reducing the layer height in that area would help reduce the effects of step over.
