Carlbosson
Variable Settyngs wizard
Wed Oct 09, 2019 2:18 pm
I set a print with 1 process up to 1.6mm from the build plate and a second for the rest of the print. I tried to print a different part but it still showed two process in the process window so I deleted the second one. Now nothing will print more then 1.6mm high! How do I fix this, Turn it off? Thanks in advance for your help.
airscapes
Re: Variable Settyngs wizard
Wed Oct 09, 2019 3:13 pm
edit the process, advance tab, top left uncheck the stop printing option. Check out the docs on how to use this feature as well as grouping process
Carlbosson
Wed Oct 09, 2019 4:12 pm
Thank you for the help. I learned about this feature from the tutorials. When this happened I when back to the tutorial but there was not a clear answer.
airscapes
Wed Oct 09, 2019 4:15 pm
Glad I could help!
