How to solve weak vertical structures
Posted: Tue Sep 02, 2014 2:38 am
Hello
Today I printed quite a large part, 10 hours worth and when I accidentally dropped it a small distance, the part snapped in 2 on a vertical pillar of cross section about 2cmx2cm. I couldnt believe it broke so easily but I know why. Here are some screenshots of the print preview and you can see what happened
Here is the part, normally
http://i.imgur.com/3L763H7.png
This is the layer just before the vertical column
http://i.imgur.com/GSZi0Xm.png
and here it is above it
http://i.imgur.com/kj6RWY6.png
As you can see, the transition from infil into wall is immediate, this resulted in a massively weak part where the infil became a shell.
Now in makerware, it does this
http://i.imgur.com/51cY99m.png
where it prints a solid sheet below the transition from infil into the vertical wall
http://i.imgur.com/DPaPiMK.png
Meaning the wall is connected to solid plastic.
This is FAR stronger. I want to know, is there any settings in simplify3D where I can fix this? If not, maybe one could be implemented. I find it quite critical.
