Perform actions automatically when import
Posted: Tue Nov 05, 2019 6:50 am
by Miklb
I always do the same actions after model import. I've tried to put some actions in the general option, rotate, put my scale... by it don't work.
What is the tip to automatically perform theses actions ?
Thanks,
Re: Perform actions automatically when import
Posted: Tue Nov 05, 2019 11:21 am
I've just set up a test to both scale and rotate a shape on import......and both work fine:
Are you setting the actions up as per above?
Posted: Tue Nov 05, 2019 11:40 am
by Miklb
Yes, but scale option isn't talking about % but mm...
I'm in 4.1.2 version
https://goopics.net/i/WeNxr
Posted: Tue Nov 05, 2019 12:43 pm
Looks like there is a bug in the French translated actions!!
As a workaround, if you change the language to English and apply the actions, I think that they will apply okay after you change the language back to French.
Posted: Wed Nov 06, 2019 2:53 am
by Miklb
Yes, thank you ! The French language causes this trouble, what a pity !
I hope it will be corrected in the next update
Posted: Thu Nov 07, 2019 8:20 am
by S3D-Alex
Thank you Miklb and dkightley for posting and rooting out this issue! I confirmed and documented this issue for the Development team. Thank you again for your help here!
