Carlbosson
First layer start point, gap
Please see attached. two layer wall thickness. As the first perimeter starts and as it comes around to set the second band it is leaving a gap. Any ideas how to fix this?
Custom FT5 R2 with Duet Wifi, Titan Aqua, .4mm nozzle, 0.1mm layer hight, PEKK 1.75mm filament, ext temp 350c, bed temp 140c enclosure temp 75c. Thank you in advance.
Carl
S3D-Alex
Re: First layer start point, gap
Is there any coast or extra restart distance being used here? Could you provide a Factory File to help us look into this for you?
Carlbosson
For give but were do I find the factory file? Do you mean the .G code file that the slicer produces?
Load your model and profile into the workspace (as if you're preparing to slice)...then File menu===>Save Factory file
