Application starts but then closes
Posted: Sun Nov 10, 2019 8:59 pm
by daveJ
Just tried to use S3D but when i click to open it it briefly starts and then closes.
Things ive done
Uninstalled and reinstalled.
Run as Administrator.
Tried opening a gcode of a previous sliced stl
All the same opens then closes
At the moment using Puser Slicer but want to get back to S3D
Cheers
Re: Application starts but then closes
Posted: Mon Nov 11, 2019 11:18 am
Try this....
Look in folder c:\users\YOURUSERNAME\AppData\Local\Simplify3D\S3D-Software for the file savedState.factory….and delete it.
If this file was corrupt, then you'll then be able to run S3D. It may be that you've previously used filenames with extended character set characters....which you should avoid.
Posted: Mon Nov 11, 2019 12:01 pm
by daveJ
Cheers
dkightley wrote:
Try this....
Works now
