STL geometry not respected?
Posted: Tue Nov 19, 2019 2:54 am
by PicoTreed
Hi all,
while slicing an STL containing a capped hole, positioned at 45° compared to the bed, I noticed a strange result that lead to "flatting" the lower side of the hole.
Moreover it also emerged a strange solid infill near the inner perimeters that it seems to me correlated to this problem:
viewtopic.php?f=9&t=14020&p=53115
Do you have any idea about that slicing results?
Thank you!
Re: STL geometry not respected?
Posted: Tue Nov 19, 2019 7:13 am
I don't think this has anything to do with the referenced thread....which relates to top and bottom multiple infill layers
I think this is an error in the stl that is causing S3D to create a solid fill across an open space.. I've seen this sort of thing before.
If you're on Win10, then load the stl into the Windows app 3DBuilder and the auto-repair on load feature will sort any shape errors out. Once loaded, save as a 3mf file...and load that file into S3D.
If you're not on Win10, then run the file through one of the online shape fixers, or use a repair program, etc.
Posted: Tue Nov 19, 2019 10:54 am
by S3D-Alex
PicoTreed wrote: ↑Tue Nov 19, 2019 2:54 am
Hi all,
Thank you!
Could you please post a Factory File for this so we can look into it further?
Posted: Wed Nov 20, 2019 2:39 am
by PicoTreed
The STL was suffering from "Self intersecting surfaces", once repaired everything went fine.
Thank you so much dkightley and Alex!
P.S. I also discovered that disabling "Merge all outlines […]" option often permit to pass over these kind of STL problems.
