S3D wont start
Posted: Tue Nov 19, 2019 10:56 am
by samsve
Hi!
Im having an issue that popped up out of nowhere. Simplify3d wont start anymore, I'm running Win 10 and it has always worked before.
I tried deleting and reinstalling the software but nothing happens when i doublecklick the icon. Tried also to start with admin rights. The only thing I've done recently is update windows, could it be that something's changed with windows?
Sammy
Re: S3D wont start
Posted: Wed Nov 20, 2019 8:43 am
by S3D-Alex
Thank you for the report. Please try opening Windows Explorer and navigating to the following directory:
C:/Users/%USERNAME%/AppData/Local/Simplify3D/S3D-Software
You may need to enable hidden folders to access this directory. Once there, please try deleting the savedState.factory file, then opening Simplify3D again.
Re: S3D wont start
Posted: Wed Nov 20, 2019 5:43 pm
by arhi
if you are not using multiple monitors then ignore this
open regedit
look under Computer\HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software
find all keys named "geometry" (there and inside sub keys) and delete them
start s3d
if it start you suffer from same bug I do :(
for me to reproduce the problem
- run on win10 with multiple screens
- move s3d to "non primary" screen
- close s3d
it will not start again till I delete "geometry" keys from registry (where it stores the windows last position) so the issue is trying to start s3d on non primary monitor...
Re: S3D wont start
Posted: Sat Jan 23, 2021 8:58 pm
by LoocPac
I have tried both of these and both do nothing.
Re: S3D wont start
Posted: Sun Feb 21, 2021 8:06 pm
by madcat3d
I went to my C drive, to C/Users/%USERNAME%/AppData/Local/Simplify3D/S3D-Software, enabled hidden folders like they suggested. AppData only became available after enabling hidden folders under properties. Then deleted "Saved State" and then also the folder named "Saved State" in that order. Then Simplify3D opened for me. That's the thing that finally worked for me, after days of screwing with this mind you. Super Annoying.
