S3D Slice / Print Problem
Posted: Tue Nov 19, 2019 2:48 pm
by ne251076
Hello together,
iam new here , my name is Nicholas. I have some trouble with my STL files to print.
I draw my things with Fusion 360. After export to STL i open it into S3D and select my printer.
When S3d Slice the object i have failures like marked in the picture.
Can somebode help me what i have to do to solve this problem ?
Nicholas
Re: S3D Slice / Print Problem
Posted: Tue Nov 19, 2019 4:10 pm
That's not any failure!! Its a SIMULATION of where a slicing effect called "coasting" is taking effect.
If you were to print, these "gaps" would not exist in the printed part.
Posted: Wed Nov 20, 2019 5:42 am
by ne251076
Hello,
thanks for the information. Can some tell me what i do wrong.
See the pictures and the marked things.
What kind of settings i have to change to get this more nice ?
Nicholas
Posted: Wed Nov 20, 2019 8:44 am
I'm afraid this is where you are going to have to do some work...….
The starting point for improving print quality is here: https://www.simplify3d.com/support/prin ... eshooting/
The issue on the handle is not that clear, but I think it is "ringing". See here: https://www.simplify3d.com/support/prin ... d-ringing/ Slowing the speed down may be the solution.
The other three issues are "blobs % zits". Se here: https://www.simplify3d.com/support/prin ... -and-zits/ You'll need to establish if the blob is being created at the start or the end of the layer.
