Can't print on Anycubic Predator directly
Posted: Sun Dec 01, 2019 12:34 pm
Have very strange problem with my Anycubic Predator. I can't print from Simplify3D via USB cable. If I generate gcode, copy and print from SD - everithing ok. But when I start printing directly - printer is halted after bed is finish heating. Empirically found out then printer halted when recieved command from serial (pic1), and after that only reconnect can help. I try Repetire - can't connect (pic2). But my second printer (i3 mega) work with both software without any problems. Also tryed change USB cable - no resault. If Cura not worked to - I would decide problem with USB on printer, but from Cura everising is ok!
