I just upgraded my Replicator2x with the BC Tech Solutions Removable Build Plate and Aluminum Arms. When the Replicator2x goes to the extruder preheat position it does not clear the build platform, so when it does a purge the filament piles up on the plate. How do I change the bed height, so the purge doesn't pile up on the bed?
I've taken a screenshot of where the starting script is kept and highlighted the lines you're probably going to want to change. If you just want to change the bed height, then maybe change that first line to Z-10 and see how that works for you.
