aruca94
ender 5 plus start gcode not working
Hello all,
I recently purchased an Ender 5 Plus. On the start gcode the machine fully heats the hotend/bed and then meshes the bed with the bltouch. After changing the start code a few times in an attempt to change the order so that it heats the bed, auto homes, meshes the bed w/ the bltouch, and then heats the extruder the machine is still not doing that. What might I be doing wrong?
Here is the start code I am playing with:
M117 homing all axes
G28 ; home all axes
M140 S{material_bed_temperature_layer_0} ; Set Heat Bed Temperature
M190 S{material_bed_temperature_layer_0} ; Wait for Heat Bed Temperature
G29 ; Auto Bed Level (BL Touch)
M104 S{material_print_temperature_layer_0} ; Set Extruder Temperature
M109 S{material_print_temperature_layer_0} ; Wait for Extruder Temperature
G1 X5 Y10 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X160 E15 F600 ; prime nozzle
G1 X180 F5000 ; quick wipe
craftyham
Re: ender 5 plus start gcode not working
I am Having the same issue with my ender 3 pro with a skr mini e3 1.2 with a bl touch. S3D is completely ignoring my start script,
G28 ; home all axes
M140 S50; set bed temp
M190 S50 ; wait for HB to reach temp
M104 S250 T0
M109 S250 ; wait for hotend temp
G29; ABL
G1 Z5 F3000 ; lift
G1 X5 Y10 F1500 ; move to prime
G1 Z0.24 F3000 ; get ready to prime
G1 Y80 E10 F600 ; prime nozzle
G1 Y100 F5000 ; quick wipe
It skips those heating presets, & is using all the layer two settings expect for the nozzle temperature. Also, starts the print at layer two after the prime line.
E3P,E3Mini1.2 bl_touch Custom Micro Swiss with a Copper E3DV6 block & 50W heater Capricorn PTFE tubing PEI flex sheet or glass Solid bed mount Trammed to 0-0.1mm.
SD3-awaiting rebirth.
