Hi all,
I have a specific problem with my Delta printer when S3D starts a print. My printer homes to the top, and it has quite a travel down after preheating the hotend then bed. Because I use PETG, this typically means I need to watch and somewhere around 5 cm remaining, pluck the oozing filament from the hotend before it touches down in the center of my print before moving to the perimeter to start the skirt.
Is there a start script I could employ that directly moves the nozzle to the outside perimeter after the home+preheat phase? As it stands, if I forget to watch the hotend down, I will have a single errant strand of filament on the bottom of my print. I tried searching the forums because I cannot believe this would be such an uncommon issue with Deltas, but maybe others print offset from the center or use PLA.
Let me know if I have a certain misconception or am going about this wrong!
