ghost surfaces problem
Posted: Thu Jan 02, 2020 8:48 am
by lucadraw
after creating my solid and saved in stl I insert it in S3D
I try to perform the procedure of printing
some openings between the central one are closed and I don't understand why
who can help me
Re: ghost surfaces problem
Posted: Thu Jan 02, 2020 12:23 pm
by S3D-Alex
It is possible this could be an issue with the model but my immediate guess is that you may have the "Merge all outlines into a single solid model" option checked. This can be found in the Advanced tab of the Process Settings. If this is not the issue could you please post a Factory File so we could look into this further?
Posted: Thu Jan 02, 2020 12:55 pm
by lucadraw
S3D-Alex wrote: ↑Thu Jan 02, 2020 12:23 pm It is possible this could be an issue with the model but my immediate guess is that you may have the "Merge all outlines into a single solid model" option checked. This can be found in the Advanced tab of the Process Settings. If this is not the issue could you please post a Factory File so we could look into this further?
YESSSS
thanks with your suggestion i solved the problem
NICEEE
