HillJonathan87
Crash on prepare to ptint
Running windows 10 64-bit. Simplify 3d 4.1.2
Any time I hit prepare to print the application locks up and I have to force quit. I've attached some logs but it doesn't seem to show much information. Software is currently totally useless.
App crash.txt
(4.94 KiB) Downloaded 128 times
Re: Crash on prepare to ptint
Try out this tip:
Re: Simplify Immediately Crashes when Opened
Report this postQuote
Mon May 13, 2019 3:59 pm
Can you please try opening Windows Explorer and navigating to the following directory:
C:/Users/%USERNAME%/AppData/Local/Simplify3D/S3D-Software
You may need to enable hidden folders to access this directory. Once there, please try deleting the savedState.factory file, then opening Simplify3D again. Please let me know if this works for you.
BigOttosan
Contact: Send private message
Mon May 13, 2019 6:23 pm
Thank you so much! It worked!
I'm sorry, but I don't know if this is also available for WIN 10
otherwise contact the S3D-support.
GER
... it works for me ... Win 10.
H.
HillJonathan87
Unfortunate no dice. It's a fresh install on this machine so there are no saved states.
horst.w wrote: ↑Sun Jan 05, 2020 6:06 pm Try out this tip:
BigOttosan
GER
H.
S3D-Alex
It is difficult to know for sure but I would guess this may be related to Graphics. Could you contact us at [email protected] so we can look into this further and provide some next steps?
