tayloralday
How To Disable Measuring (16 Points) When Starting a Print
Mon Jan 13, 2020 9:55 pm
I have a Creality CR-10S Pro and Simplify3D. Whenever I go to start a print, the bed goes through all 16 points like I am trying to auto bed level or something. This is annoying for the fact that it puts down filament everywhere before the print actually starts. I used Cura before I could purchase Simplify and it never did that. I am thinking there is a certain setting or something I am looking over... Any help would be much appreciated!
Thanks in advance, Taylor.
S3D-Alex
Re: How To Disable Measuring (16 Points) When Starting a Print
Tue Jan 14, 2020 9:43 am
The Creality CR-10S Pro has a G29 in the starting script. This is what causes the auto-leveling routine to occur. If you do not want this to happen you can either delete the line from the starting script of comment the code out by putting a semi-colon at the beginning of the line like so ";G29".
