Hi forum. I am putting together a new printer. I have a BigTreeTech SKR v1.3 controller running Marlin 2.0_bugfix that I cannot get to connect with Simplify3D. It connects fine to Pronterface using the same settings. It will connect to Simplify3d but it does not action any data arriving on the serial port. It fills the buffer with outgoing commands (which the printer responds to) and then stops working when the buffer is full. If I increase the size of the buffer I get to send more commands before it stops working
I can connect to the printer with Atom and see with the serial monitor that the skr board is sending the 'ok's and the temperature data in response to a M105 command but Simplify3d does not display the temperatures - so basically Simplify3d does not receive any data on the USB serial. I have tried both the Maplin_USB driver and the Smoothieboard_USB driver. I have also had to uncheck the 'wait for startup command' in tools\firmware config or else it just wont connect at all. Simp[lify3d works fine with my older printers running Marlin 1.9 .
anybody suggest anything before I go back to a mega2560 and marlin 1.9.....
