Thin-wall printing bug
Posted: Thu Jan 16, 2020 9:45 pm
Scenario:
Start with a solid model, which is then shelled to the nominal width of the print extrusion. The CAD software's shell algorithm will adjust according to the slope of the surface, so that sloped walls will have a thicker linewidth when sliced by S3D. Setting thin wall behavior to "allow single extrusion walls" will accomodate the thicker linewidths for sloped walls, however a bug occurs when the extrusion goes from printing a vertical wall to a sloped wall. In the attached image, endpoint modifications (like wipe and endpoint extension) were turned off for clarity in the S3D simulation screenshot. In the printed result the otherwise pristine surface can be turned into a hot mess from all the unnecessary extrusion stops and starts.
Any suggestions on how to stop this? I admit I'm mystified why the toolpath algorithm thinks its a good idea to stop an extrusion, only to restart it at the next index position. I go through a lot of time and effort to create designs that hide the extrusion start/stops, and this vertical-to-sloped wall issue really compounds the difficulty.
