dealing with DRM woes
Posted: Tue Jan 21, 2020 2:16 pm
by cj11363
TL;DR : Is anybody out there using both Simplify3D and Cura, and if so, how do you handle synchronizing settings across the two slicers ?
Let me start by saying that I really like Simplify3d. I've tried several different slicers, and s3d works best for me. Having said that, for me, s3d actually no longer works.
I've recently migrated from a Mac desktop to linux ( Elementary OS, Juno, an Ubuntu 18.04 derivative ) and DRM issues have prevented me from using S3D for the last 4 days. When I try to start Simplify3d it hangs. More specifically:
charlie@charlie-Precision-7740:~$ /opt/Simplify3D-4.1.2/Simplify3D
[1]+ Stopped /opt/Simplify3D-4.1.2/Simplify3D
charlie@charlie-Precision-7740:~$ fg
^C
These s3d hangs have been a common occurrence since I started this Mac to linux transition, and my "fix" was to go to my simplify3d account page , deactivate the license for my linux machine, and then re-install s3d. Apparently I've exceeded a limit on deactivation's and now I'm locked out of deactivating licenses ( and there's a license for a Windows machine I no longer own that I'd really like to deactivate, sigh... ). Does anyone know if being locked out of deactivating licenses is a lifetime ban, or will this functionality eventually be restored ?
When I reached out to support@simplify3d about my inability to run Simplify3d, they deactivated my linux license ( thank you ) and pointed me to a "special" version of the linux installer which is supposed to solve my problem. However, the instructions I received start with exporting my profiles before running the special installer, and obviously I can't export my profiles if I can't start S3d. sigh....
In searching the forums it looks like the problem I'm experiencing, or one very much like it, has existed for at least 4 1/2 years and I'm hoping that somebody on this forum can offer guidance on how they've handled DRM issues.
I used Simplify3d for years on a Mac and never had any DRM isssues ( and I am regretting my recent Dell/linux purchase, but that's another story...). I think that my particular issue is linux related, but perhaps not?
What seems clear to me is that I can no longer depend on Simplify3D as my only slicer solution. I've managed to install and configure Cura for one of my printers, and for a single filament. It needs a bit of tweaking, but at least I'm able to continue with my current project.
However, I've spent a bit of time tweaking Simplify3d for my workflow and I'd REALLY like to get at the information in my S3d profiles, particularly my start scripts. I do have profiles that I exported a couple of months ago, when I first started migrating from OSX to linux, so worst case is that I might be able do a fresh install of S3d and start over from there. Not optimal, but it could be worse.
thanks,
--Charlie
Re: dealing with DRM woes
Posted: Tue Jan 21, 2020 9:12 pm
by arhi
cj11363 wrote: ↑Tue Jan 21, 2020 2:16 pm like to get at the information in my S3d profiles, particularly my start scripts.
I was able to extract some data from windows registry but I doubt that can help with mac/linux version :( no clue where they store the data or how, BUT, ALL your data about profile used to create GCODE is stored in the GCODE file itself, at the begining of the file in comments... so if you have saved any of your GCODE files you can extract all the data (including start scripts) from the GCODE files itself ... so get your gcodes from your sdcard and .. it will be some manual work but you can easily extract them from gcode and into ideamaker or, if you so desire, cura
e.g.
; G-Code generated by Simplify3D(R) Version 4.1.2
; Jan 8, 2020 at 11:16:42 PM
; Settings Summary
;   processName,Process1
;   applyToModels,N8
;   profileName,PETG (modified)
;   profileVersion,2019-11-05 14:21:32
;   baseProfile,Default
;   printMaterial,PETG
;   printQuality,High
;   startingGcode,M17,G28,G28 Z,M200 D0,,
;   endingGcode,M104 S0,M140 S0,
the scripts use "comma" to replace new line, so
converts to start code that's:
M17
G28
G28 Z
M200 D0
Posted: Thu Jan 23, 2020 11:58 am
by cj11363
Very nice. I hadn't thought about using the gcode to extract profile information ( "use the source Luke" :) ).
Support got me up and running again with Simplify3d, but there may be a way that I can use gcode to sync some simplify 3d profiles with Cura...
thanks!
/cj
Posted: Thu Jan 23, 2020 12:57 pm
by S3D-Jake
arhi wrote: ↑Tue Jan 21, 2020 9:12 pm
I was able to extract some data from windows registry but I doubt that can help with mac/linux version :( no clue where they store the data or how.....
They should be in XML format on linux and mac in the following locations respectively.
Linux: $HOME/.config/Simplify3D/S3D-Software.conf
Mac OS: /Users/$USER/Library/Preferences/com.Simplify3D.S3D-Software.plist
Posted: Thu Jan 23, 2020 3:11 pm
by arhi
S3D-Jake wrote: ↑Thu Jan 23, 2020 12:57 pm They should be in XML format on linux and mac in the following locations respectively.
that's perfect :)
easier to extract than from registry :)
cj11363 wrote: sync some simplify 3d profiles with Cura...
yeah should be possible to write plugin for other slicers to import s3d settings from gcode file
also @S3D-Jake could get their developer to implement feature in s3d to import ideamaker/cura/prusaslicer/slic3r... profile directly into s3d too
Posted: Wed Feb 02, 2022 12:08 pm
by bnorman
This is an old thread, but this is also an old problem. I've always had difficulty with S3D DRM on linux. Regular system updates (Fedora and Ubuntu) often cause the license to become invalid, and I have to deactivate them on the website. A couple of times, I've lost the ability to reset them through the website and have to contact support. This just happened, and I'm not optimistic about getting a reply in a reasonable time frame. In addition to creating custom tools and objects, I have a printer so that I can quickly replace random parts that break on tools, household items, etc. in the course of other projects. If I have to dork around with support to use software THAT I PAID $150 FOR, I get more than a little irritated.
I'm going to have to migrate to a different slicer today (like I have time for that), and I don't expect I'll be going back to S3D. I'm weary of doing the right thing and supporting developers by purchasing software only to be screwed by DRM nonsense. It's happened more times than I can count.
Posted: Thu Feb 10, 2022 7:45 pm
by tenaja
I liked s3d before it was stagnant. I tried Cura for its ironing, and kept using it because it's now much more capable. Sure, the s3d interface is nicer, and it's got one or two extra features that I rarely use, but overall Cura is my slicer of choice.
Posted: Fri Feb 11, 2022 8:12 am
by gwhite
I use PrusaSlicer for a lot of my day to day prints. However, there are still things S3D does better, and I occasionally have to switch back. I ran a print last week that had a mysterious deformation in PrusaSlicer, but it came out perfect in S3D. I think it's a bug in PrusaSlicer, but I have no idea what could be causing it. PS doesn't have nearly the detailed control you can get with S3D of things like temperature, cooling or supports.
