will4836
Infill not Slicing/printing
Tue Jan 21, 2020 7:09 pm
Hi all,
I have just begun using S3D and am having an issue with my print. I am trying to print a part for a model airplane which has thin 0.4mm walls. However, there are some areas that are solid which I would like to have infilled. For some reason these areas will not slice with any infill though - they are just hollow.
Any suggestions? I have attached the STL file below (for some reason I can't attach the IPT file - any thoughts?)
Any help is very appreciated! Thanks - Jim
T1.stl
(28.7 KiB) Downloaded 58 times
