Heaters shut off after first layer
Posted: Thu Jan 23, 2020 5:46 pm
by soreloser
Where could I find the setting that could help me continue with the bed and nozzle heat during a print? I have tested the same print thru a different slicer and i do not have this problem.
Re: Heaters shut off after first layer
Posted: Fri Jan 24, 2020 11:25 am
by S3D-Alex
If a temperature setpoint is set in the Temperature tab of the software then it will continue for the entire print. Could you please post a Factory File so we can look into this and see what may be happening?
