Flashforge Creator Max no extrusion after nozzle purge
Posted: Wed Jan 29, 2020 1:46 am
by aackerman
Apologies if I put this question in the wrong place- I'm new here...
I just bought the new Flashforge creator max, which is essentially the new version of the creator pro. I am having a problem where after the nozzle is finished doing its purge, there is no extrusion whatsoever. This problem only occurs with S3D as I've confirmed that the printer works perfectly using Flashforge's slicer Flashprint. In other words, no, its not a clogged nozzle. I've been using a FF creator pro for nearly four years with S3D and I've never experienced a similar problem. I've compared the gcode from S3D to the gcode from Flashprint and I can't find any differences. I'm fairly certain that the starting script in S3D is fine as everything executes perfectly (note I had to change a few things from default because the FFCP configuration was causing crashes on all axes during homing). I've attached my gcode from S3D in the hopes that someone can help me track down the cause of this problem.
Thanks in advance
Re: Flashforge Creator Max no extrusion after nozzle purge
Posted: Thu Jan 30, 2020 3:35 pm
by S3D-Jake
Thanks for attaching your S3D generated print files. I'd suggest first looking at what a working G-Code file looks like for this new machine. You can quickly get this example to work from by using FlashPrint. I've included the first 50 lines of a 20mm cube sliced from FlashPrint. FlashPrint also doesn't export X3G files for this printer, so I'd say don't try to run those types of files.
;generated by ffslicer 1.24.0 01/30/20 15:21:17
;layer_height: 0.18
;perimeter_shells: 2
;top_solid_layers: 3
;bottom_solid_layers: 3
;fill_density: 15%
;fill_pattern: line
;base_print_speed: 60
;travel_speed: 80
;right_extruder_temperature: 200
;left_extruder_temperature: 0
;platform_temperature: 50
;right_extruder_temperature_raft0: 0
;left_extruder_temperature_raft0: 0
;right_extruder_temperature_reset:
;left_extruder_temperature_reset:
;start gcode
N1 M118 X25.00 Y25.00 Z20.00 T0
N2 M140 S50 T0
N3 M104 S200 T0
N4 M104 S0 T1
N5 M107
N6 G90
N7 G28
N8 M132 X Y Z A B
N9 G1 Z50.000 F420
N10 G161 X Y F3300
N11 M7 T0
N12 M6 T0
N13 M651
N14 M907 X100 Y100 Z40 A80 B20
;layer_count: 111
N15 M108 T0
N16 G1 X25.00 Y-25.00 F4800
;preExtrude:0.20
;preExtruder0
N17 M108 T0
N18 G1 Z.200 F420
N19 G1 X25.00 Y-25.00 F4800
N20 G1 X25.00 Y5.00 E4.3504 F1200
N21 G1 X-5.00 Y5.00 E8.7009
N22 G1 X-5.00 Y-25.00 E13.0513
N23 G1 X25.00 Y-25.00 E17.4017
;raft
;layer:0.27
;shell
N24 M106
N25 G1 E16.1017 F1800
N26 G1 Z.270 F420
N27 G1 X19.40 Y-19.40 F4200
To my eyes this code looks similar to the header used in the Adventurer 3 and Creator 3 profiles. I'd start there. In all honesty though you should discuss this with our support team.
Have you contacted our support team?
