Z Seam manual input ignored....
Posted: Sun Feb 02, 2020 7:48 pm
When I try to manually set the Z-seam location when I slice the file it is ignored and preview shows the seam at a corner as it would when selecting "optimized"
I'm trying to calibrate pressure advance. File is a 100mm cube, 1.2mm walls (0.6 nozzle). Trying to generate the seam in the middle of a side of the cube. No matter what combination of X/Y values I input they are disregarded. It simply selects the closest corner to the X or Y coordinate that I select.
I tried moving the X coordinate 10mm at a time, once I input a value beyond the middle of the wall (X>250), the retraction location jumps to the right corner of the model, anything less than the middle (X<250)
