ghosty
Brim Speed
Hi
i would like to see the ability to change the speed brims print at, for larger parts its not such a problem but small fiddly bits with lots of direction changes need to be significantly slower.
For some reason first layer speed does not seem to effect the brim speed, I have watched many times the brims get thrown down at print speed in a mess, and then the head slows to do the actual parts.
To combat this I currently use two processes, one at 20mm/sec fir the first 2 layers, and then another for printing at preferred print speed.
Thanks
Ty
Re: Brim Speed
Can you attach a factory file for an example of when the brim isn't getting first layer speed applied?
