Geeetech A10T multi material
Posted: Fri Feb 07, 2020 10:33 am
by eddyuk
Does someone has experience of using Geeetech A10T with multiple different materials?
I want to use PLA and PVA for support. Was playing with Cura and seems that it is kind of works but way from being correct.
Does Simplify3D can handle that? Geeetech A10T has 3 extruders and 1 hotend.
Re: Geeetech A10T multi material
Posted: Fri Feb 07, 2020 1:05 pm
by DarthRevan
I've not done this. And I wouldn't suggest it. The three or two in and one out nozzle printers work best when you keep the materials the same. PVA and PLA need to print at different temperatures, speeds, etc.
You'd be better off trying to use dual materials with a printer that has separate nozzles and heaters.
Posted: Tue Feb 18, 2020 2:35 am
by Daniel-J
I agree, it could be a bad situation if the same heating is used.
Posted: Sat Jun 06, 2020 2:07 am
by clintondiya
S3D allows you to use multiple processes for different print settings but I think it only works in vertical layers. In your example if you were to rotate that model so the blue part was on the print bed you could define a process to print 20% infill to a predetermined height then switch to 100% around the hole then back to 20% to top off the cube.
I'm about to upgrade from an A10M to an A10T, but I've used OctoPrint on the A10M with no issues, so I don't see why the A10T would be any different. I'd say I'd update you soon, but shipping delays are obviously happening with what's going on in the world right now.
Just note that with any of the X-in-1-out setups, if you slice in Cura or another slicer, you can specify using the different extruders, but you won't have any color mixing without using Geeetech's software.
If you want to use multi-color printing, you'll definitely want to have purge towers (or some other purge setup) to clear out as it switches from one filament to the other, and this may take some tweaking to get set up correctly.
