Hollow object without closed body, slicer adding bottom
Posted: Tue Feb 11, 2020 1:01 pm
by tef11
Hello All -
Brand new to 3Dprinting, and have run some tests with other software. I don't know all the terminology, so forgive my ignorance as I'm learning. Print came out fine but need to print on a larger printer (German RepRap X500). Using this software (which is different from software I used for original print) the slicer is adding a bottom, gaps, and added material. Attached are images of the import in preview mode, and one when prepared for print. Any tips?
Re: Hollow object without closed body, slicer adding bottom
Posted: Wed Feb 12, 2020 2:26 am
by PicoTreed
Hi tef11,
please share wit us your STL, anyway you can try to:
  • export again or fix your STL;
  • play with the "Slicing Behavior" settings in the "Advanced" tab.
Posted: Tue Feb 18, 2020 3:19 pm
by tef11
Thanks, that worked. On to my next issue...posted recently!
