Legionis
Fixing broken STL File
Hello,
im not quite sure whether this is the right forum but I give it a shot.
My brother wanted me to print a model of his wifes car (Opel Corsa model C).
Unfortunately the STL File he sent me (attached) is broken in simplify for me and all my efforts of flipping normals in simplify or edditing the shell in fusion360 did not really work. I only want the outer shell to be printet, without all of the interiour.
Does anyone have some tips or suggestions on what I can do to achieve this?
I did not find any other models of this car in the internet, so this is all I have unfortunately.
Greetings
Lukas
Mesh.step.stl
(1.04 MiB) Downloaded 156 times
Re: Fixing broken STL File
Hi
from where you have downloaded the Corsa?
There is a model in www.thingiverse.com what is running well for me. The only one complication, it is nearly not visible when opened in S3D. Select the models name in the left window and chose Edit > Drop Model to Table; than you can scale it unlimited.
Your file seems corrupted, origin it may be an step-file, transformed to stl. My CAD program can't open it, the messages is Unknown Characters found.
GER
The file contains something like 300 separate meshes that appear to be all jumbled up together. There are internal details and lots of faces that are defined inconsistently for a 3D printer to be able to touch. I think it was originally designed to be rendered in a 3D graphics engine...and not for 3D printing
I can get it somewhere near to a solid model that might print....but there's a hell of a lot of corruption to the door windows...and the wheels have lost their spokes. If you are on Windows 10, load the stl into the Windows App 3DBuilder and let it repair it.
