Hello Simplify3d Team!
I am trying to find a way to get rid of the first-layer-smoosh-out effect. Basically you need the first layer to smoosh alittle so you get good adhesion to the bed but the smooshing causes the first layer to overhang by .25 to .5 mm beyond the demensions of the model. This causes you to either use a tool to remove the overhang which messes up the look of the part or just deal with it.
I am requesting the ability to remove the outer most wall path on the first layer only. This will allow me to over extrude just alittle for good infill and bed adhesion without the overhang.
I'm going to try and to this myself in the gcode to test but I think it will help alot of people!
Thanks!
