Filament stops feeding for unknown reason
Posted: Sun Feb 23, 2020 1:04 pm
I have a new printer, an Eryone Thinker S. It has been working well, but in recent days the flow of filament stops part way thru a print - it's as though an M18 E has been issued. This seems to be repeatable, the flow stops part way thru the first layer in the same place.
Issuing an M17 E doesn't re-enable the feed, but starting the job again does - it will start feeding and then fail again in the same spot. Once it stops I can't feed filament manually.
I can't for the life of me understand why this is happening. If it was caused by filament jam causing the E0 circuit to fail I would expect that to be random, and it isn't, it fails every time in the same place. All other steppers continue to work, it's just the E0 which stops responding.
I'd be grateful for any comments.
