bjoern79de
Calibration
One thing I miss is the ability to use variables like "Coasting Distance = {layer-number} * x".
If I want to calibrate some parameters, I have to create one process for each value (even if I can semi-automate splitting a process, I have to type in huge amounts of numbers - especially if I want to combine multiple parameters).
I would like to spread a range of i.e. 100 values across 100 layers, measure the height of the best results and calculate which value(s) has been used at the appropriate layer.
