bug w/ add/remove supports
Posted: Sat Sep 20, 2014 5:31 pm
by dennisjm
OS=OSX 10.9
Setup=macbook pro w/ external monitor attached.
Bug=If you put S3D on the 2nd monitor, add/remove supports doesn't work. If I move it back to the main monitor on the laptop it works as expected.
Re: bug w/ add/remove supports
Posted: Sat Sep 20, 2014 5:42 pm
by dennisjm
Another thing that doesn't work on the 2nd monitor is clicking another model in the view area when there are more than one model selected and having the new model become selected. You have to manually click the model in the dialog instead.
Posted: Sat Sep 20, 2014 8:11 pm
by jimc
Dennis, thats a strange one right there. Im running a late 09 iMac and s3d always runs on my second monitor. Never had any issue like that. I dont even know what would cause such an issue to help. Have you tried different settings for monitor 2? Maybe try it as a mirror of the main display instead of an extension and see if it does the same thing.
Posted: Sat Sep 20, 2014 9:36 pm
by dennisjm
I have a retina display laptop. I think it's something to do with the resolution switching when it moves between monitors. A version or two ago they had the bug where on Retina displays support tool wasn't working. They fixed that OK but I don't think they included code to switch between the retina and non retina displays.
Posted: Sat Sep 20, 2014 11:08 pm
by jimc
ahhh yes thats right. i believe the fix back then was to open s3d in low res mode or something like that. can you do that with your main monitor so they are both just regular hd and not do the switching? my imac isnt retina but it is 2560x1440 and my second monitor is regular 1080p. i dont have an issue there except everything looks bigger on the 1080p monitor. retina however may be a completely different story.
