HPB temp issue with 2.1.2
Posted: Sun Sep 21, 2014 6:37 pm
by kencfii
I upgraded to 2.1.2
Now the HBP setting seems to be ignored.
I have it set to 65 degree but it prints as no heat applied.....
I have a flash forge creator and never had a problem but now it does not register the temp I set for the HBP.
I can run older files I created off the SD and it works great.
I even changed the temp a few degrees in my latest print to see if that would work.
No help.
Basically it will not put the HBP temp in the gcode...
any ideas... older versions work just fine....
does the new software version have an issue?
I tried in repG and makerware and it works fine
help?????
Re: HPB temp issue with 2.1.2
Posted: Thu Oct 02, 2014 4:16 pm
by KeyboardWarrior
Go to Help-->Configuration Assistant then select Flash Forge Creator. This should do a semi-reset of your settings, and the heated build plate should work after that. It's possible your process settings got messed up, like the Temperature Identifier or your Firmware Configuration wasn't set correctly to Replicator 1-dual printer, but either way using the Configuration Assistant will revert back to the defaults and it should work.
