Change noozle size inside a same print?
Posted: Tue Mar 31, 2020 5:40 am
Hello,
I got a Prusa I3 MK3. I was wondering if their is a way to use 2 different noozle sizes during a print on a printer with only one extruder? Imagine a large one, i would start with a 0.6mm noozle for the base wich is a simple shape, then the printer reach end of process 1, is put to pause, i change the noozle for a 0.4mm one and the print resume on process 2 wich is made for the 0.4mm noozle. I know about the M600 command for color change but it's inside a same process as far as i understand. Any way to do what i want? All we need is a way to pause the printer at the end of process 1, move the printhead up and resume on process 2 after noozle change.
You could also imagine a print with very small detail on top, by example a text that needs the 0.25mm noozle when the rest of the part is good with a 0.4. I would need to print the most of the part with 0.4mm noozle then switch to the 0.25mm one for the small text on top. How to do it, if possible?
Thanks
Thanks
