Page 1 of 2
Horizontal Surfaces Missing
Posted: Wed Apr 08, 2020 10:02 pm
by brearcd1
I have an issue where horizontal surfaces are not solid.
Note that this is not an issue with the top layers, but with any solid horizontal layers not printing on top of the infill.
This has also occurred with the underside of a model.
Any suggestions will be appreciated.
Thanks,
--Dale
S3D Version 1.4.2
Printer: ProMega
Re: Horizontal Surfaces Missing
Posted: Tue Apr 14, 2020 10:47 am
by S3D-Alex
Could you provide some images or a Factory File to help show what you are referring to here?
Posted: Tue Apr 14, 2020 11:08 am
by brearcd1
I tried to attach image files to my original post.
Let me try this again.
--Dale
Posted: Tue Apr 14, 2020 11:10 am
by brearcd1
Missing again, although they appeared in the attachments tab.
Obviously operator error since I've seen others do this. :D
Posted: Wed Apr 15, 2020 10:04 am
by brearcd1
Any hints on adding images as attachments?
Mine do not seem to appear when I post.
Trying to attach images again.
And again not attached...
Thanks.
Posted: Wed Apr 15, 2020 1:13 pm
See my post in this thread: viewtopic.php?f=9&t=13043&p=49920&hilit ... ent#p49920
No futher instructions needed. Its self-explanatory!
Posted: Wed Apr 15, 2020 1:24 pm
by brearcd1
That is precisely the process I was using with Firefox.
Trying Chrome now.
And no images. Apparently it does not work every time...
Posted: Wed Apr 15, 2020 1:44 pm
1) Click on the button marked "Attachments"
2) Click on the button that then appears marked "Add Files!
3) In the File Select window that opens, browse and select the file on your computer and click "Open"
That's it! Type the rest of your post. Simples!
PHPbb ( or should I say phpBB ), which is the forum software used here, is compatible with all well known browsers...and always has been!
Posted: Wed Apr 15, 2020 2:33 pm
by brearcd1
Those are the steps I've followed, as well as dragging the image to the message box.
And if either of these worked there would be two pictures attached to this post.
Thanks for trying.
Posted: Thu Apr 16, 2020 9:43 am
by brearcd1
Repeating from above:
Note that this is not an issue with the top layers of the print, but with any solid horizontal layers not printing on top of the infill.
External links to images below:
Calibration Cat: http://www.tangledinfo.com/files/cat.jpg
Door Handle: http://www.tangledinfo.com/files/handle.jpg
