cura profiles -> s3d profiles
Posted: Thu Apr 09, 2020 5:28 am
by skelator
I'm trying to translate the cura option from
https://3dverkstan.se/protective-visor/ ... int-guide/ to the closest s3d setting, I never used cura before so I'm have no cluse where to start, can anyone help?
Thanks!
Re: cura profiles -> s3d profiles
Posted: Tue Apr 14, 2020 10:49 am
by S3D-Alex
Could you let me know what settings specifically you need assistance with? It looks like they are recommending you edit the Infill %, Layer Height, Extrusion Width and some of the Print Speeds. Which of these were you having issues with?
Posted: Tue Apr 14, 2020 9:50 pm
by skelator
S3D-Alex wrote: ↑Tue Apr 14, 2020 10:49 am
Hi Alex,
I'm looking for the same setting for these
- 2020-03-22-03_08_06-ultimaker-cura.png (3.16 KiB) Viewed 15205 times
This means that the optimal line width is:
0.4mm nozzle -> Set line width to 0.5mm
0.6mm nozzle -> Set line width to 0.66 or 0.8mm
0.8 mm nozzle -> Set line width to 0.8mm or 1.0mm
1.0mm nozzle -> Set line width to 1.0mm
1.2mm nozzle -> Set line width to 1.33mm
how do we achieve this in s3d I can only find how set layer height, ultimately how do I configure s3d to use different layer height/width example below
0.8 line witdth
0.3 layer height
Thanks!
Posted: Sun Apr 19, 2020 9:43 am
by BrainMcFly
set in "Extruder " Extrusion witdth to "manual" and set it to 0.8 mm (Its line width, but line is in s3d called extrusion
in "Layer" set layer height to 0.3mm
