Upgraded and have some issues
Posted: Mon Apr 20, 2020 9:08 am
by Larac
Hey all,
Started printing mask straps and such.
Made the mistake and upgraded my software.
Is there a way to undo the update?
These used to work with no issue.
2 issues:
1: Heated build plate
It used to allow me to set the temp, now it pulls the extruder, temp.
Clicking the Build Plate does not change it.
Used the T0 and T1 settings it still trys to set build plate to Extruder temps.
2: Extruder 1
I have 2 Extruders 0 and 1
The software now seems to no care at all if I tell it to use extruder 1, it still goes to extruder 0, no matter the settings.
All setting are set to Extruder 1, but when I start a print extruder 0 is heated up.
So could use some help, or a degrade from the update.
I understand some additions do G Code may fix some of this, but it should not be needed.
Thanks all.
Re: Upgraded and have some issues
Posted: Mon Apr 20, 2020 9:28 am
by Larac
More digging seems all my profiles are hosed.
So rebuilding each.
Will see if this works.
