Z Retract At End
Posted: Tue Apr 21, 2020 7:50 pm
by TheIcon1681
Is there a way to make the nozel tip retract at the end of the program? Right now, my machine stops on the top surface of the part. I use a Wanhao I3+
Re: Z Retract At End
Posted: Fri Apr 24, 2020 2:06 pm
by S3D-Alex
If you want the Z axis to raise after a print you would want to use something like the following in your Ending Script:
G91 ; set to relative positioning
G1 Z5 F1000 ; move Z axis up
G90 ; set to absolute positioning
This would move the Z axis 5mm up from wherever the print stopped. As a warning though this can cause issues if you are printing parts that are close to using up the full Z build volume. Usually you would just want to home the X and Y axes to get the nozzle away from the part after the build is complete.
Posted: Sun Apr 26, 2020 10:16 am
by Giulio999
Hi
I'm very new to this game would this script work on my Snapmaker Original as mine always stops at the top of the print then slowly burns down into it spoiling the end product which is really frustrating after waiting for 10hrs for it to end I've checked the troubleshooting and there's nothing there to help
Posted: Tue Apr 28, 2020 1:01 pm
by S3D-Alex
Are you using the Snapmaker profile available in the software? I would recommend loading this and using that profile as it has an ending script that will raise the Z to the Max value when the print is complete.
Posted: Wed Apr 29, 2020 9:31 am
by Giulio999
All sorted now thanx
