Simlify 3d first layer issues.
Posted: Mon Apr 27, 2020 10:57 am
Hello! Im currently using a Flashforge Creator Pro and am very new to 3d printing. I switched over to simplify 3d last night as i was tired of the lack of control in flashforges limited options in its slicer. I was having lots of issues with first layer adhesion because their software does the first layer at the same speed of every other layer and was not allowing it any time to adhere. So i switched to simplify 3d for the extra control. the issue im having is that after slicing my first part and running the printer it is at first making a bunch of random squares near where its going to print without actually extruding any material then by the time it goes to print its first layer its seriously high. I tried messing with the global z setting and currently have it at -.25 and its still too high and just curling ABS back on itself without it ever really touching the bed and compounding matters is that because its spending 30-40 seconds making invisible squares for itself a little bit of filiment is leaking out of the extruder and giving any filiment that does touch the base a much more attractive place to adhere and im left with just a ball of molten goo on the extruder. any help at all as to what direction to go next would be wonderful, so far very frustrated with this rather pricey software even if its just because of my own ignorance. Id seriously appreciate any and all help!
Flashforge Creator pro.
ABS filiment
extruder 230c
bed 110c
first layer speed 30%
and before you ask, yes the bed is immaculately clean, ive leveled it a dozen times in frustration so far and the extruder is cleaned carefully after each failed attempt.
ABS filiment
extruder 230c
bed 110c
