Dual extrusion and precise scaling & first layer issue
Posted: Sun Sep 28, 2014 12:01 am
Scaling
I'm unable to find a way to scale 2 objects by % for dual extrusion.
While I can import the 2 stl files, merge them with SHIFT+Center and Arrange and scale them with the mouse by SHIFT+CTRL+Right Mouse button, I'm unable to scale them to a precise % like I could by right clicking the object individually and adjusting the scale to e.g. 1.2.
If the objects are scaled individually by right click, they will not line up later for dual extrusion and I have to fall back to Makerware for all my non default size dual extrusion prints.
Any ideas? Or is this feature missing in S3D?
First Layer
Another issue I have is that S3D apparently prints, independent of the model used, a full layer for both models, with the 2nd extruder as soon as it reaches the level in question. Take the thingiverse traffic cone for example (http://www.thingiverse.com/thing:21773). The ring version (_RINGS) has a small inner ring starting from layer 1 or 2. S3D will print the inner ring as well as the full layer, including the square base with the second extruder. Does this have something to do with the first layer height setting maybe? Does S3D add this first later for the 2nd extruder in-between layers if this is left enabled?
Thanks !
Scaling
First Layer
Thanks !
