Mon Apr 27, 2020 3:11 pm
It is just a warning you are exiting "safe zone", safe to ignore it. Safe zone for .6mm nozzle is ~.7mm (0.6*1.2 or 0.6*1.25) width with up to 0.58m (0.6*0.8) layer but s3d adds another relation of layer height < width / 1.2
so with your manual 0.6 width it will allow you to set layer height up to 0.5mm
since your layer is set to 0.45 I assume you are using "combine" either for infill or support, if you have "combine infill every 2 layers" then infill layer will be 0.9mm and that's more than 0.5mm so warning (same for support)
Embed M117 codes into G-Code
open source and unlicence
