The problem I'm currently facing is that Simplify3D is adding a lot of single point retractions in the inner side of the outer wall, you can see all the points in the top part of the following image:
It looks like some kind of "reinforcement" that Simplify3D is trying to add... But I don't want it.
This provokes a lot of retractions at each layer, causing filament churning and even some layer shifting (or something similar). The issue I'm most concerned with is those unnecessary retractions.
I'm currently using a 0.4 nozzle, I've set the Nozzle Diameter to 0.4, Extrusion Multiplier to 0,96, and Extrusion Width to 0,40. Layer height is 0,26.
If I change the extrusion width to 0,46, the blobs disappear. Changing the layer height or the extrusion multiplier does not make a difference. I've also tried setting the Thin Wall Behavior to perimeters only, but it doesn't make a difference. Changing the number of outer perimeters makes no difference either.
What can I do? Thanks in advance.
