Flashforge Guider II / IIS
Posted: Fri May 15, 2020 9:42 am
by jayceekeys
Hi all,
I've been using Simpify3D for many years.
I've just bought a Flashforge Guider IIS and tried to connect the printer to S3D. It has Wi-Fi and LAN, however know that it is only likely to be possible to connect using USB - which I have tried.
I cannot get the control panel to connect to the printer. It shows in the list of ports as Port_#0002.Hub_#0002 which looks odd in itself. When I select this and try the default baud of 115200 it times out with the following info:
Attempting connection at 11121/9/00000000050C...
WARNING: Unable to open device
Error connecting to selected device.
Has anyone managed to connect this printer?
Best wishes,
Jay :)
Re: Flashforge Guider II / IIS
Posted: Thu May 28, 2020 8:48 pm
by markw
While this may not help other than to confirm that the USB connection from S3D to the guider iis does not work. I see the same issue and have tried a number of cables and different USB ports. After trying various combinations, all of which failed, I gave up.
My solution has been to write the file from S3D to disk, rename the file to filename.g from filename.gcode, load the g code it into Flashprint and send the file to the printer from there. Flashprint connects reliably using USB and wireless so I am not sure why S3D has such difficulty with a relatively common process.
Mark.
