Keep Factory Filename for save
Posted: Fri May 22, 2020 1:36 am
by domiwettstein
Allready existing factory file is saved with the name of the first objects name, instead of the opened filename.
Request: Save factory file with CTRL-S should allways use the same name as opened.
Re: Keep Factory Filename for save
Posted: Wed May 27, 2020 2:08 pm
by S3D-Jake
I believe this depends on how the factory file was opened. If it was automatically opened by the software (like in the case of you re-opening the software) the model's name is used. If you goto Load factory file, then the Ctrl + S option does save the factory file with the same name as the loaded factory file.
Posted: Mon Jun 01, 2020 1:16 pm
by domiwettstein
S3D keeps the the folder Location in mind, wehre the last Project was opened instead of the origin path and filename.
