Model Settings Movement
Posted: Fri Oct 03, 2014 2:13 am
by Monty3DP
Hi Guys,
hoping i can get a quick answer...
Is there a way I can set the amount that each push on the up or down arrow changes the input value by for say moving the object along an axis...
At the moment, it's moving the object by about 20mm at every click of the up or down arrow. And for fine adjustments, I'll like to change this to about 0.5mm or even less.
Re: Model Settings Movement
Posted: Fri Oct 03, 2014 6:04 am
by JoeJ
I just use the mouse/keyboard shortcuts. I can move the part precisely enough using the mouse and that way I don't have to bother with clicking that little up/down arrow. The shortcuts are in the quick start guide if you don't know what they are
